Page 1 of 2
Re: Help with iphone cases please
Posted: 23 Mar 2013, 18:01
by sehmus99
hi i was just trying to do some iphone cases but just cant manage to get a smooth finish tired loads of different times temps but just not working for me im not sure what im doing wrong..... so i thought let me see if anyone else has had the same problem and found a solution to it.
the printer im using is a ricoh sg3110dn
temps tried: 190 - 60sec, 175 - 120 secs, 190 - 40 secs etc
any advises?
http://img607.imageshack.us/img607/8602/img7439u.jpg
http://img839.imageshack.us/img839/3568/img7438z.jpg
Posted: 23 Mar 2013, 18:04
by bms
Did you take the plastic protective coating off before pressing?
Posted: 23 Mar 2013, 18:13
by sehmus99
sorry forgot to mention that yes i did remove the clear coating.
Posted: 23 Mar 2013, 18:22
by Mattie
Are you pressing print side down and using a soft/medium pressure i do them like this at 190 for 45-55 secs
Posted: 23 Mar 2013, 18:34
by sehmus99
metal side on top, i was thinking could it be the paper im actually using?
Posted: 23 Mar 2013, 18:39
by Mattie
I cant see paper effecting texture, it could coating melting to easy, where did you get cases from
Posted: 23 Mar 2013, 18:44
by sehmus99
i got them from a seller on aliexpress (china), i've watched quite a few videos online in all of them paper sticks to the metal but mine dont.
Posted: 23 Mar 2013, 19:13
by Mattie
Sounds like the coating could be rubbish n melting to easy, did they not give you time n temp. I've never had paper stick to any of the cases i press including samsung, blackberry, htc etc
Posted: 23 Mar 2013, 20:54
by JMugs
If the image looks good when you look at it square on, then you are getting the fine pattern from the platen or its cover, use a silicon sheet between the platen and the paper. this will smooth everything out. if the image is poor when you look at it square on then ignore the above.
Not saying I have the answer, just the answer to a problem I had in the past.
Janners
Posted: 23 Mar 2013, 21:24
by pisquee
Are your covers kept somewhere nice and warm and dry, or somewhere cold and/or damp?
If the latter - it could be a moisture thing -- pre press them before using,or put them somewhere warm before using
