Me Again - PixMax Mug Press
Re: Me Again - PixMax Mug Press
I have the Pix Max Mug press. I thought I'd try it out today and make a birthday mug for a friend. It's come out very faded and the word 'girl' hasn't come out either. The instructions say Temp 310 and Time 120. I'm using a Ricoh SG3110DN printer. When the mug is in the press the blanket does not look a tight fit ..and I have tried tightening/ loosening and it doesn't seem to make a difference. Any ideas?
I do 150 seconds at 195 degrees, you'll have to convert, fairly tight pressure, make sure you're printing on the right side, do multiple tests using the same mugs, saves wastage.
are you sure is Celsiusnot Fahrenheit? Also whats the source of your mugs? are they descent?
