Re: print banding on bottom
Posted: 21 Mar 2013, 19:16
by NIGELG
Hi All having problems with the usual epson 1400 printer taken all week to get the b****y thing working purchased a new ciss and refillable cartridges and all a disaster i have to say.
So I stripped down my old bulk ink system cleaned it and the cartridges and its almost working apart from light cyan not working but i wont give in spent to much money so cant buy anything new to replace it !:mad:
Any how i have another problem with banding at the bottom of the page.
when it comes to the bottom last 1cm it slows down and causes a banding anyone any ideas ?
cheers
Posted: 21 Mar 2013, 19:55
by bms
Banding at the bottom of the page sounds like the ink is not being replenished to the cartridges quickly enough. There may be a blockage in the tubes/ cartridge where some ink does get through but not enough to keep the print perfect.
Edit: Have you put in the genuine cartridges to prove the printer is fine and it is the ink flow of the sublimation system causing the problem?
Posted: 21 Mar 2013, 20:01
by pisquee
Does the situation improve when just using the refill carts and not the CISS?
Posted: 21 Mar 2013, 20:28
by socialgiraffe
Banding can also be caused by a computer to printer data error.
I do get this myself sometimes, normally when I send 20+ pages to the printer. I have never bothered to try and fix it as it does not bother me that much but exactly the same as what you are describing happens to me. The printer stops printing and sits there flashing. Eventually it prints a little bit then spews the paper out.
I am using a Ricoh so if the problem is a data error the Epson is not at fault.
I am running Windows 7 Ultimate.
Posted: 31 Mar 2013, 16:30
by NIGELG
Hi there sorry for long delay been in rehab for Epson 1400 Printers........................ still trying to sort out printer, still getting blocked nozzles will check print again when working properly.
This print problem did happen before even when the CISS was ok its when it comes to the edge of the page and slows down it seems to over print for some reason
cheers Nigel
Posted: 31 Mar 2013, 16:35
by NIGELG
no its that lasts bit when it comes to the bottom of the page and slows down as it prints to to the edge it seems to over print some how ill photo it and put it on forum probably make sense:confused:
still trying to sort out blocked printer nozzles today.................... very slowly running out of Artanium ink then another £300 quid i suppose :mad:
thank you for replying
