New Postage charges - you think its all over it could be now!!
Re: New Postage charges - you think its all over it could be now!!
On good authority we have sneaked a look at the new Royal Mail postage prices coming in shortly. If it goes ahead you are looking at the following
1 x Mug in Poly box first class - £5.65 (Then your box and packing on top)
1 x Baseball Cap - £5.65 (Plus your packaging)unless you squash it flat as a pancake.
so minimum realist price now for a mug posted will be £11 - not such a cheap fun item now.
Just shows RM is getting prices up ready for the sell off so that the difference between Royal Mail and courier services isnt vast.
I wish I could put my prices up as easily
Need this like a hole in the head!!
Assuming the above is correct then I can see the Mothers day/Personalised/Valentines/one off etc mug business by post is dead in the water............thanks for nothing Post Office.
Prices have been released for a while now!
1 mug will be £3.00 - not £5.65 - there is an exception to the rule on small parcels - not sure if a poly box will fit but cardboard box, with mug, definitely does.
There is already a long thread with this info on.
Price list for anyone that is interested HERE
exceptions are 16x16x16 cm box and some postal tubes
Although we are lucky because they only made the exceptions at the last minute due to complaints from the proposal
Still a bugger for things like bags and teddys though
Does the Royal Mail website have that information publicly available? I couldn't see it today when our franking machine got updated. It's likely that postal services will now be severely reduced from April 2nd from us in preference of courier services.viccar;67876 wrote:exceptions are 16x16x16 cm box and some postal tubes
On my post, 2 above yours Martin, click the HERE, zoom in, scroll down, its on the second page. :biggrin:
http://www.royalmail.com/parcels-made-easy
[TABLE="class: caption-less, width: 100%]
[TR]
[TH]Exceptions apply[/TH]
[/TR]
[TR]
[TD] The following items are also priced as Small Parcels:
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
- Parcels that measure up to and including:
Length: 16cm and Width: 16cm and Depth: 16cm - Roll or cylinder shaped parcels that measure up to and including:
Length: 45cm and Diameter: 8cm
[/TR]
[/TABLE]
ThanksJohn G;67892 wrote:On my post, 2 above yours Martin, click the HERE, zoom in, scroll down, its on the second page. :biggrin:
thanks for that John G................
if i,m reading that right - parcels up to 1kg - is that £2.60 for a mug in box for 2nd class ? £3.00 for first ?
so 40p hike on 2nd class post and 30p on first :rolleyes:
Yes, that's correct - and if its the right size box you may be able to send 2 mugs for the same price.parcels up to 1kg - is that £2.60 for a mug in box for 2nd class ? £3.00 for first ?
