Page 1 of 3
Re: Lines on Ricoh sg3110
Posted: 08 Feb 2013, 10:23
by Dave271069
the image on left is with Epson sx130 and on the right is my Ricoh, can anyone advise me why im getting a faint line across the image, Image
Posted: 08 Feb 2013, 12:08
by Dave271069
ive completed a head clean but still lines , would low ink (not empty) be a cause?
Posted: 08 Feb 2013, 16:41
by JMugs
Go to the BMS website, click on the ricoh printer bit, click on the video, from about 20 minutes onwards (if my memory is right) it will tell you how to do your alignments etc. It's simple but takes about 15 minutes. That banding is characteristic of paper feed alignment, print head alignment etc.
Follow the guide do all stages and I am sure all will be fine. Some of the checks should be done on a regular basis, and all of them should have done when you first set the printer up.
So make a cuppa, follow the video, and it will probably be hunky dory.
Janners
Posted: 08 Feb 2013, 17:23
by Dave271069
Thanks, will check it out, all I can say is thank god I didn't sell my epson, worth it's weight in gold at the moment.
Posted: 08 Feb 2013, 19:06
by Dave271069
just as bad now, Image
Posted: 08 Feb 2013, 20:07
by RogerC
The banding looks bad enough to possibly something in the original. Is the colour profile correct on the Ricoh? What format are you printing in?
Posted: 08 Feb 2013, 20:10
by Dave271069
I have windows 8 but using the sawgrass profile, not powerdriver. If i get chance later i will print it out on my laptop with windows 7 etc.
Posted: 09 Feb 2013, 16:20
by Dave271069
cleaned heads, flushed heads, done alignment, not sure what to do next! printer is no use to me with banding lines like im getting, getting really annoyed now!
Posted: 09 Feb 2013, 18:04
by JMugs
Have you phoned sawgrass helpline?
If not, why not?
Have you spoken to your supplier?
If not , why not?
Really these are your first ports of call. Use them. Save yourself the agro, or you'll get all stressed.
You have a good printer, you may have a duff one, it happens.
I had a problem with mine. The support and service from BMS, and Sawgrass was excellent.
Janners.
Posted: 09 Feb 2013, 18:17
by Dave271069
Can't make calls, bought off here, was working fine before just started happening recently, also I thought the forum was my first place of call due to it being such a friendly place there is a chance it's happened to someone else ?
With all the flushes and head cleans I've done I'm now out of black so will need to buy some, might just buy a full set as the others are low also, hopefully that's the problem.
