Re: Multifunctional Digital Mug Press
Posted: 31 Jan 2013, 21:20
by Tania
I have just purchased this mug press from BMS. I understand how the setting work as it is almost identical to the flat press. I set it ok, when it started bleeping, I pressed the go button and it just switches between 230 and 233, it does not reach temperature and does not count down. I have switched it off and left it but it won't even let me re-set it now! I wondered if anyone had a solution. Some of the digits don't display properly either.
Posted: 31 Jan 2013, 22:09
by bms
Tania;64427 wrote:I have just purchased this mug press from BMS. I understand how the setting work as it is almost identical to the flat press. I set it ok, when it started bleeping, I pressed the go button and it just switches between 230 and 233, it does not reach temperature and does not count down. I have switched it off and left it but it won't even let me re-set it now! I wondered if anyone had a solution. Some of the digits don't display properly either.
What are the three settings that you have the press set to?
Posted: 31 Jan 2013, 22:22
by Tania
We followed the instruction in the book. 230f and 330f. Thanks
Posted: 01 Feb 2013, 07:38
by bms
Tania;64439 wrote:We followed the instruction in the book. 230f and 330f. Thanks
Posted: 02 Feb 2013, 19:11
by Tania
Hi
Thanks for your reply, apparently the control unit is faulty. A new one was despatched yesterday, a great service!
kind regards
