Page 1 of 2
Re: Ready to finally buy my Ricoh A3 and now it's out of stock at BMS......if.....
Posted: 22 Jan 2013, 12:24
by FairyD
I buy the printer and first set of inks from another authorised retailer am I then 'bound' to them for follow up inks or will I still get the same support if I chase for the cheapest price when I go to re-ink as long as it's one of Sawgrass' retailers!?!?!?
Posted: 22 Jan 2013, 13:10
by RogerC
The support comes from Sawgrass as I understand it so as long as you use genuine Sawgrass inks it really shouldn't matter where you get them from.
Posted: 22 Jan 2013, 13:13
by socialgiraffe
RogerC is right.
As long as you purchase Sawgrass Inks you can purchase them from any seller.
I just purchased a set from Listawoods because they have the DSF Members 10% discount so pretty much the cheapest at the mo.
Posted: 22 Jan 2013, 13:17
by John G
I've been using sublijet-r carts from BMS, I've also seen them on various other sites but with different packaging - something like visi-sub.
Now I''m not sure whether you can use both at the same time (as in 1 cyan using sublijet-r and a yellow using visi-sub) - that would be a good question for Sawgrass to answer.
Posted: 22 Jan 2013, 13:53
by FairyD
Brilliant, thank you everyone......x
Posted: 22 Jan 2013, 14:00
by viccar
John G;63652 wrote:I've been using sublijet-r carts from BMS, I've also seen them on various other sites but with different packaging - something like visi-sub.
Not sure if you can use the both at the same time, but the visi-sub uses the same powerdriver and profiles as the Sublijet, i think i read somewhere that they are the same just different packaging, but cant find the thread now.
Posted: 22 Jan 2013, 14:02
by viccar
Posted: 22 Jan 2013, 14:08
by FairyD
Yikes...just checked the prices with the other suppliers....I'll just need to sit on my hands until it's back in stock!! MARTIN.......when's it back in stock!!
Posted: 22 Jan 2013, 15:03
by pisquee
Sawgrass inks are pretty much price fixed, so you'll be lucky to find much of a price difference between dealers.
Posted: 22 Jan 2013, 15:23
by FairyD
All ordered, went through Listawood..coming tomorrow with BMS order hopefully the next day which will give me a chance to get it all set up!!! Can't wait...now I can finally see if the graphics I've been working on will print well!!!!!!!!!:redface:
