Cutting Sublimation Stickers with Vinyl Cutter
Re: Cutting Sublimation Stickers with Vinyl Cutter
I bought a length of sublimation sticker vinyl, the images transferred onto it pretty well, it's a bit see through, and I then put it though the cutter with limited success, it cut ok but it was almost too brittle to weed - has anyone had any luck and are there other products that might be softer I could try. It could be an excellent occasional use alternative for some types of work.
Sorry i dont know the answer but im interested to know how this works
ive seen this http://www.printerowners.co.uk/sublimat ... ticker.htm
Do you just print it and press it? and then cut round it and stick it to say a window?
and is it permanent or can it be removed easily.
That's the stuff, you sublimate onto is as you would any other blank, it's worth getting a bit to experiment with. It's a thin plastic and can be removed easily but at the same time it wont come off unless you deliberately pull it off. What would be great is if I could bung it though the cutter.
