Re: Mug press
Posted: 12 Jan 2013, 11:38
by kezza99
Hi Guys
I have cleared my weekend to print the order for mugs I received and my mug press has decided to print the mugs faded. It is a few years old so guess it has had its day. I have decided to invest in a new one. Would prefer one that does 2 mugs. Any suggesions?
Also BMS and Listawood have single mug presses but very different in price. What should I be looking for in a good mug press?
Re: Mug press
Posted: 12 Jan 2013, 11:46
by Paul
this one?
or two of them for less then twin head
Re: Mug press
Posted: 12 Jan 2013, 12:33
by RogerC
Mine is a single from BMS and to date (touch wood) it has always done an excellent job. If I was looking for the ability to print two at a time I would have two single presses from BMS. The reason is if anything did go wrong with one I would still be able to continue production on the other. With a twin if something goes wrong with the 'electrickery' controls you are stopped dead.
Re: Mug press
Posted: 12 Jan 2013, 12:40
by viccar
If the rest is working fine, why not just get a new blanket.
Two the same sounds good, then if one goes wrong, you have spare parts for the other one.
Re: Mug press
Posted: 12 Jan 2013, 13:02
by kezza99
It's an old thing. I think I got from eBay and you cannot replace the blanket. Which one would you recommend from BMS Roger?
Think def the route is two singles, good point made!
Re: Mug press
Posted: 12 Jan 2013, 14:22
by RogerC
kerry;62775 wrote:It's an old thing. I think I got from eBay and you cannot replace the blanket. Which one would you recommend from BMS Roger?
Hi Kerry...I have the DF1. It is easy to use. As a complete beginner to this when I bought from BMS I found that from then until now they have been nothing but excellent to deal with. I even visited them twice and couldn't have been made more welcome.
Re: Mug press
Posted: 12 Jan 2013, 14:29
I use both the cheap Chinese BMS press and also a single head Adkins same as above. I might be upgrading and if I do it will be to either the Adkins twin head or serigraf four head.
