Re: Inserts for heart shape compact mirrors
Posted: 25 Nov 2012, 16:29
Anyone any idea where i can just get the insert metal bit from?
Can your supplier of the compact mirrors not get these for you?viccar;59757 wrote:Anyone any idea where i can just get the insert metal bit from?
Martin, I once tried to get spare ones from Xpres who told me they don't do spare inserts which, means you are left with something you cannot sell.bms;59768 wrote:Can your supplier of the compact mirrors not get these for you?
Any spares are available but it depends if the suppliers buy them in. I presume if the item is relatively cheap then spares aren't brought in as the item isn't that expensive to just buy again.Ian M;59769 wrote:Martin, I once tried to get spare ones from Xpres who told me they don't do spare inserts which, means you are left with something you cannot sell.
Missing one of themviccar;59772 wrote: Ps Martin... are u missing your tape gun
What I did with similar heart-shaped inserts was to take a picture of the insert lying on a flat surface from vertically above it. I then loaded the photo into Photoshop, levelled it up and scaled it to the size of the original insert plus a tiny amount for 'bleed.' This gave me a template to work from which worked very well.markromain;117958 wrote:Could anyone supply the psd template for the heart shape compact mirror.
