Page 1 of 2
Re: Epson Stylus Office WF7015
Posted: 16 Nov 2012, 13:07
by twinsgran
Does anyone have this printer? Is it any good and where do you get your sub inks from please?
Posted: 16 Nov 2012, 13:50
by Ian M
Susan, the Epson WF7015 isn't a supported printer for dye sublimation prints. May I suggest you have a read of the following link which should help you decide which printer to use. http://www.dyesubforum.co.uk/vbforum/sh ... ch-Printer
Posted: 16 Nov 2012, 17:39
by twinsgran
Thanks for the link. I'll go and have a read. I asked about this particular printer as it's the follow-on from the B1100, which I was going get but they are hard to come by, so thought I'd go for the newer version as it seems to be about the same price as the B1100...around £190. I definitely need an A3, but need to keep the cost down to a minimum.
Posted: 16 Nov 2012, 19:25
by pisquee
If going for an unsupported A3, then Brother printers may also be an option
Posted: 16 Nov 2012, 19:36
by WorthDoingRight
For those interested here is the current list of Sawgrass supported printers:
Ricoh: http://www.sawgrasseurope.com/consumer- ... ters/ricoh
Epson: http://www.sawgrasseurope.com/consumer- ... ters/epson
From those lists you will see that currently Ricoh has the GXe7700N, and Epson the B1100/T1100 and 1500W as supported A3/A3+ printers.
Posted: 16 Nov 2012, 19:44
by twinsgran
Any suggestions on which brother to go for?
Posted: 16 Nov 2012, 21:46
by bms
Ian M;59004 wrote:Susan, the Epson WF7015 isn't a supported printer for dye sublimation prints. May I suggest you have a read of the following link which should help you decide which printer to use. http://www.dyesubforum.co.uk/vbforum/sh ... ch-Printer
Not supported in the UK yet, but it is in the US.
Posted: 16 Nov 2012, 21:59
by twinsgran
Oh it's all soooo confusing!!:confused:
Posted: 16 Nov 2012, 22:05
by bms
twinsgran;59029 wrote:Oh it's all soooo confusing!!:confused:
It shouldn't be. The Epson A3 is the Photo 1500. The Ricoh A3 is the GXe7700.
Ask yourself if you really need an A3 printer as A3's are much more expensive than A4
If you go the unsupported route then expect a learning curve with very limited help from other users as opposed to warranty support and back up from an authorised distributor.
Posted: 16 Nov 2012, 22:38
by twinsgran
Thanks Martin. Yes I do need an A3 for the jigsaws I'm going to do.
You've been a great help. Cheers.
