Re: Mug Image Position
Posted: 25 Oct 2012, 12:31
Hi,
I've been given an image which is not wide enough to wrap around a mug properly, but it is too big to double the picture up so it appears on both sides.
So I was wondering would you put the image in the center of the mug (parrallel to the handle) or over to one of the sides?
Usually I would ask the customer, but if the customer had given you no particular preference then what would you do?
Obviously theres no definitive answer to this and I suppose you could get away with either I just wondered if there was a norm when it came to this kind of thing.
Heres some pictures of the image and positioning to help explain better
