First Timer Needs Help.
- Rabbit Stoker
Re: First Timer Needs Help.
Hi guys
Im all new to this sublimation stuff and have hit a problem already (suprise suprise).
When I print using sub ink my prints are all washed out and grainy, Is this normal for sub ink?
my normal epsom ink prints fine but the sub ink dosent any ideas ??
thanks in advance
rabbit
thanks in advance
rabbit
Yes
heave a cup of tea and read the forum
Please search for dull image via forum search. Also i presume you dont use suported printer, ink and icc profile?? And also have yo pressed anything yet??
First thoughts are you are either printing onto wrong paper or wrong side. What brand are you using as the carrier paper?
- WorthDoingRight
If you are talking about the image on the paper prior to transferring to an item then it will look very flat and dull (and even sometimes the colours will look odd) - but if you have the correct ICC profile etc then once transferred the image should be fine!
Can you please tell us what printer & inks you are using as this will help us. Do you mean the print when it has just come out of the printer or do you mean when you have pressed an item as this will help too.Rabbit Stoker;56280 wrote:Hi guys
thanks in advance
rabbit
- Rabbit Stoker
ok I'm using a epson sx215 printer and to be honest I got the paper from ebay and it has no brand label on it, i have goten ink from ebay (seller says that they are left over from their work and worked fine for them ) I also bought ink from china.
The print on paper is faded and grainy (the black is more like smoky grey) and when sublimated onto a mug it looks worn out and faded
lick your finger and see what side is sticky... you should print on one that is stickyRabbit Stoker;56292 wrote:ok I'm using a epson sx215 printer and to be honest I got the paper from ebay and it has no brand label on it, i have goten ink from ebay (seller says that they are left over from their work and worked fine for them ) I also bought ink from china.
Aaron, first of all your printer isn't supported for doing sublimation but, there is a way around this as you will need a custom ICC Profile to get the colours correct. Paul should be able to help you out with this. I have no idea what the ink from China is as most of us use licensed ink from Sawgrass. As Martin says 'Let the learning curve begin...'Rabbit Stoker;56292 wrote:ok I'm using a epson sx215 printer and to be honest I got the paper from ebay and it has no brand label on it, i have goten ink from ebay (seller says that they are left over from their work and worked fine for them ) I also bought ink from china.
I would NOT recommend to do icc for ink that you don't know. as when ink runs out you will have to get another one!
as I said in my previous post... have a cup and read a lot
All the best!
All the best!
Users browsing this forum: Google [Bot] and 7 guests
