What you get.
Vinyl cutting machine, (Media Size 710MM)
Heat press, (38cm x 38 cm )
8 rolls of vinyl in various colours (61cm wide x 5 meters long)
Application tape
Tools for vinyl work
Cutting software
Cutting mat
7 new cutting blades
Some small samples of vinyl for clothing.
Ideal for starting up a small home business.
The vinyl cutter is in great working order info below
Media Size 710MM/
The flat bed heat press is also in great working order and condition.
The pressing surface size is 38cm x 38cm This is ideal for pressing vinyl onto clothing.(Different vinyl to what i have but it can be purchased easily from various suppliers)
I have approx 8 rolls of sign vinyl(not for clothing) to get you started.
Which are 61cm wide and approx 5 meters long in various colors including metallic gold and silver.
£400 ovno for everything collection only from the County Durham Area.
Vinyl cutting machine, Flat bed heat press, Rolls of Vinyl, Cutting software+ more
Re: Vinyl cutting machine, Flat bed heat press, Rolls of Vinyl, Cutting software+ more
- vB_ID:1131
- press.jpg (56.67 KiB) Viewed 653 times
whats the make of the cutter?
TC631 Cutter/plotter Features
USB2.0 Interface, Support Hot-Swappable, With Serial Port to support more long-distance data transaction
64MB Super-Memory,Long time Offline Cutting, The data Storage can be achieved even Blackout
Copy last job feature, automatically store in internal flash memory (up to 99 copies even after power off).
New High-Speed PIC Remote Control System, Higher Speed while Lower Noise
Digital Force & Speed Adjustable, Direct & Steady
Humane Design, Allows to adjust cutting force and speed while working
High-Precision "Steel Bardbed" Axis,Higher Accuracy
Auto Memory of Blade Force & Speed. Ajustable at any time,easy to use
Emergency Stop & Stop to return at any time to monitor the cutting quality
Unique red cutting slot make it easier to operate
Support all Windows (Vista 64bit require signature option Disable), Mac OS X 10.3+ support with Signcut Pro via Serial to usb adaptor* (Optional not included)
*For mac support we can only support if you buy one of our Usb-Serial Adaptor because not all the adapter are the same even with the same chip set as many customer found out the bad way after many hours of frustrations. However if you decided that you don't need it, contact us and send it back with in 14 days, we will exchange it with a pack of plotter blade (worth £2 more) instead.
Specifications
Driver: Stepper Motor Control
Media Size: 710MM/27.95"
Cutting Size: 630MM/24.80"
Max Cutting Speed: 800 MM/S
Max Pressure 800 Grams (can cut any vinyl)
LCD With, Aluminum Stand With
Pinch Roller: 3
Buffer Capacity: 64 MB
Resolution: 0.025 MM/Step
Repeatability: 0.1 MM/0.0039 IN
Interface: USB2.0/Serial
Content Include
1x TC631 Cutter/plotter Unit
1x Aluminum Stand with Lockable Wheels
2x Superior Ball-bearing Bual Roller
3x High Quality 45 Degree Cutter Blade
1x Cutting Blade Holder
1x Pen Holder with Blue Ink Cartridge (for plotter drawing)
1x USB Cable
1x Serial Cable
1x Cd with Windows Driver, Corel Draw Driver & PDF Manual
1x Dust cover
The Press
The make is hp3805b
The pressing surface size is 350mm x 350 mm
Press Description:
Digital high pressure heat press machine
Specification:
Voltage: 220V, 110V;
Watts: 1400W;
Temperature range: 0-399degree;
Time control: 0-999sec;
Specifications
Pinch Roller: 3
Content Include
1x USB Cable
1x Serial Cable
1x Dust cover
The Press
The make is hp3805b
Press Description:
Specification:
Watts: 1400W;
Where abouts in durham are you
They have now been sold
