Page 1 of 11
Re: Cutter .. Cameo ?
Posted: 27 Jun 2012, 19:42
by Kahboose
Thinking of just going for the Cameo Cutter from BMS , Just wondering how easy it is to use it for weeding transfers for inkjet prints ?
Also i have a heatpress on order but will i need anything else to start vinyl printing on t-shirts ? for example software tools (obviously a weed tool) but anything else ?
cheers
Posted: 27 Jun 2012, 19:50
by Paul
cameo will come with basic software so all you need is heat press, some vinyl and cutter
and off you go
Posted: 27 Jun 2012, 19:53
by Kahboose
Thats superb , so tempted to go order the Cameo cutter .. and some vinyl and spend the weekend playing.
Would you know what the basic software is capable off ? im guessing basic letters numbers etc .. I currently use photoshop can vectors for the cameo be made in that program ?
Posted: 27 Jun 2012, 19:58
by bassqee
The cameo is brilliant, not had a problem with it. Weedind is only as hard as you make it with your designs. It comes with a sticky carrier for when your cutting paper, cardboard etc.
It has a trace function so you can import an image and trace it easily to create the lines for cutting.
Posted: 27 Jun 2012, 20:03
by Paul
Kahboose;48597 wrote:Thats superb , so tempted to go order the Cameo cutter .. and some vinyl and spend the weekend playing.
photoshop is not vector software. so for this you would need corelDraw, illustrator or free inkscape.
Iam sure standard cameo soft can do bit more then text and numbers
Posted: 27 Jun 2012, 20:06
by Kahboose
Cheers guys i think im going to order one , wished i had earlier it would have came tomorrow with my press
Posted: 27 Jun 2012, 20:13
by Paul
if you do it tonight it still will be with you by weekend
c'mon! you want it!
Posted: 27 Jun 2012, 20:21
by bassqee
I just played about with the software to get some good results - you basically select the area of the image you want to trace fiddle with a few different sliders and see what happens, you soon get a feel for how easily it can be done such as these ones.
[ATTACH=CONFIG]1068[/ATTACH]
Posted: 27 Jun 2012, 20:23
by Kahboose
just looking on BMS now , would any of you know if the A4 vinyl sheets would work in the cameo ? you know thw ones labeled for the Robo ?
this one ?
starter kit
Posted: 27 Jun 2012, 20:26
by Paul
yes. you can cut up to A3 i believe. CR is A4.
