Hi
i was wondering if anyone has pressed the novelty mugs from the transfer press company, i am pressing them at 190deg cel for 170sec the way i do all my other mugs but when i pressed these novelty mugs at the same time and temp the one mug was a bit dull and the other one the paper had stuck to the mug has anyone got any suggestions.
thanks
malcolm
novelty mugs
Re: novelty mugs
I suspect this is to do with the coating on the mug and is probably softer than normal coatings. I'm sure Graeme will be able to advise you of the recommended settings for these if you drop him an email.hakuna;46938 wrote:Hi
thanks
malcolm
