Re: how to position photo in photoshop
Posted: 26 May 2012, 12:11
by plugy
When i put a mug template in Photoshop and ready to print it goes to the centre of the page so there is a lot of waste how do I move the image up the page so i can get maybe one or more prints on the paper thanks
Posted: 26 May 2012, 13:00
by ASO Embroidery
Hi plugy
Im by no means an expert on photo shop but this is how i do it someone else may come along and tell you an easier way but here goes. where you would normally have your image ready on the screen go to select all at the top of the page. you would now normally go to copy then paste. instead of copy select copy merged. Then go to File select (new) a dialogue box will open where it says preset ( clipboard) change to international paper go to size change to A4 click ok you should now see a new blank page go to( paste ) you now have your selected design you can now just copy and paste any further images you wish as normal by just dragging in to the position you want told you i was no expert but hope this makes sense to you if not repost and will try and explain better Paul is probably the best man for this he would normally put up some form of graphic for you but hope it helps.
sammy.
Posted: 26 May 2012, 13:29
by johnw
i just cut my paper in half and create a custom paper size
Posted: 26 May 2012, 14:18
by NASH
all you to is to select the item with the marqee tool then move with the arrow tool bar to the top of the page
Posted: 26 May 2012, 14:42
by smitch6
when u go to print there is a 'centre image' box it is ticked just un-tick it then repostion it
Posted: 26 May 2012, 19:14
by bassqee
as smitch says - when you go to the print section you can reposition your image.
