Re: Only ever happens when you are busy
Posted: 19 Mar 2012, 20:47
My creation P cut, for a while some of the push buttons have been getting a bit harder to use, tonight the -pressure button, nothing at all, and i need to change that to cut anything as i was cutting some really thick reflective vinyl, and now i cant use it.
take out my back up creation p cut, thinking i will swap over the cutters or swap over the control panel - and they are different, the 2nd one has no baud settings on it when you scroll through ( i have never used this one, it was bought as part of a job lot, and have never had to use it) so cant swap over the control panel. so i thought just use this cutter, its serial port, so go out and buy a serial to usb adaptor, and now whatever setting i set it on, nothing
also have a refine which i was going to use at the workshop, again, bought but never used, seems to not like signblazer, so looks like might have to see if it will use another programme.
could really really do without having to buy another cutter when i have 3 here...... but
so will call the engineer tomorrow and see how much a new control panel is for my creation, and see if his brains can be picked as to why the other creation has no baud settings on the control panel and see if he can help.
