Re: ricoh print quality
Posted: 05 Mar 2012, 20:34
by harry tambo
hi,i,m using the e3300n ricoh,sublimating text onto metal.results are faint black,any suggestions to getting a better print?turned heat press down to 190 and 60 secs sub time,however still paper sticks to metal and the print is black ,but quite faint still.any suggestions?:mad:
Posted: 05 Mar 2012, 20:40
by bms
Go down to 170 - 175 degrees and 50 seconds. Blacks go off to brown and blurred when you are too hot for too long with ricoh inks.
by John G
Are you using sublimation Ink - (sublijet - R gel ink)
Are you using the powerdriver or if a mac a profile.
What paper are you using and where from
What metal are you using and where from
As much info as possible and it will help with your replies.
Posted: 09 Mar 2012, 00:46
by harry tambo
thanks mate...
Posted: 09 Mar 2012, 00:51
by harry tambo
thanks john,sublijet,china paper from ebay,coted metal from xpress,just corel windows 7,not shire on the driver??
Posted: 09 Mar 2012, 09:14
by John G
Well, along with your timings, that could be a problem. You need to be using either the powerdriver or a profile.
Posted: 09 Mar 2012, 19:16
by bms
harry tambo;41992 wrote:thanks john,sublijet,china paper from ebay,coted metal from xpress,just corel windows 7,not shire on the driver??
Make sure you use PowerDriver which is available as a free download from here...
http://www.sawgrasseurope.com/technical ... sublijet-r
Posted: 15 Apr 2012, 02:53
by Martin cull
I never did work out why.... But if I printed the same eps file from illustrator and Corel draw, the illustrator version would give a far better result on the finished product... This was on my old Ricoh GX7000
Posted: 15 Apr 2012, 08:51
by John G
Maybe the profile/powerdriver wasn't set up properly in coreldraw
