Never done one so aint got a clue at moment.
Sublim Tshirts
Re: Sublim Tshirts
are these done the same way as you would do the mugs or is it is different transfer paper.(and yeh i know i dont put tshirt in mug press
Re: Sublim Tshirts
Hi Cardman,
I've done them with xpres paper before no problem, make sure you put some greaseproof paper inbetween the t'shirt as the print can transfer to the back and also protect your heat platen with another sheet of greaseproof paper. I use the stuff from the supermarkets.
Cheers John
Cheers John
Re: Sublim Tshirts
i got sublim paper that i use for the mugs - so in theory i could just print on them and so long as tshirt was sublim it would work ??
Also is it better to print with sublim inks as thats only printer i have besides a color laser
Re: Sublim Tshirts
That's what sublimation t' shirt are for sublimation. They have a high content of polyester - you HAVE to use sublimation ink on these shirts. The greaseproof paper is to protect your heat press and the back of the shirt.
And yes, use the same paper that you use for mugs - though you can get a higher release paper which is supposed to give better results.
Cheers John
Cheers John
Re: Sublim Tshirts
I noticed texprint give better results as can relase more ink then other papers. But you can use any sublimation paper but need to press for slightly bit longer.
Re: Sublim Tshirts
You can use certain colour laser printers to print onto t-shirts. There are a few different type of laser materials for going onto light coloured and dark coloured t-shirts.cardman;37825 wrote:i got sublim paper that i use for the mugs - so in theory i could just print on them and so long as tshirt was sublim it would work ??
Re: Sublim Tshirts
Hi Martin. Can you tell me more about the laser transfer onto t-shirts. What is needed and how is the process done? Can any type of t-shirt be used?
Re: Sublim Tshirts
The Vapor t shirts are far more like a "real" t shirt, personally I find the usuall subli ones a bit naff. The process of subbing onto a shirt I find is much better than the laser option as the image is impregnated into the material not sat on top.
