Printing problems D120
purpledragon
Re: Printing problems D120
Post by purpledragon »
HI
you do sound in a pickle feel free to give me a ring 01437 765612 if i can help i will.
It sounds like some of your problems could be due to slightly blocked heads this would give a stripy effect
Brett
Hi Michelle,
Have you performed a nozzle check first to make sure your nozzles are clear before going to print? The stipe effect will be down to a blocked nozzle and there's no point in printing first before this is sorted.
If you're the Michelle that is local(ish) to us then please call us at the office and we can make a time for you to call round with the printer and easyflow system to get this sorted out for you (if you're using a laptop then you could bring that as well to make sure everything is correctly configured).
Michelle J
Post by Michelle J »
Thanks for your help guys!
Martin - I would love to come over so you can help me with it if you dont mind. I didnt want to take up anymore of your time, but i would really appreciate it. I've left you a message at the office, so pls call me back on 01425 612461 when you get a chance to sort out a time.
Thanks!
Jules
Post by Jules »
I too have a D120 and the heads always need about 3-4 cleans if I haven't used it for a few days. Does anyone know if it wastes a lot of ink doing head cleans? Thanks, Jules
You do use quite a bit if ink everytime you do a head clean - if you watch the yellow tube you can probably see ink being drawn through.
Georgestreets
Post by Georgestreets »
I have been having red light probs with the D120. A bit useless me thinks.
