Page 1 of 2
Re: Help needed mh721 cutter plotter
Posted: 24 Jan 2012, 14:07
by wayne
Hello all
I have a major problem with my mh721 the usb port got damaged (snapped off on the inside) so I have installed a serial port on my pc and I am now using the serial port but the cutter can not be found by the software, i am using flexisign and signblazer please help
Posted: 24 Jan 2012, 14:24
by cardman
u got your setting right for serial port as i heard they can be a right pain to setup
Also make sure u got it set to com 1
Posted: 24 Jan 2012, 14:32
by wayne
Thank you for the reply I have tried all the ports inc com1 still no luck
Posted: 24 Jan 2012, 14:43
by Paul
are you sure is under com 1 on your pc?? if so did you check in the production menager in flexi com is changes as well?
whats mh721??
Posted: 24 Jan 2012, 15:04
by wayne
Yes made sure both settings were the same mh721 is a cheap cutter plotter
Posted: 24 Jan 2012, 15:23
by Paul
but it must have a name :rolleyes:
uscutters one?
Posted: 24 Jan 2012, 15:32
by wayne
thats the one
Posted: 24 Jan 2012, 15:38
by Paul
is it set like this?
and also have you got this thicked here?
any error msgs??
Posted: 24 Jan 2012, 16:04
by wayne
what software is this? we have v8.1 ?
Posted: 24 Jan 2012, 16:09
by Paul
this is flexi10 but manager looks same in previous flexi
