Re: lines through image
Posted: 13 Jan 2012, 20:55
by colglyn
Hi all
new epson printer was working all ok until tonight, nozzle checks all ok (did 3 head cleans and now 100%) but when printing i got lines
running through the whole image, i've done print head alignment but lines still running through, the lines are like the ink has match up
completley when printing, any advice thanks harry
Posted: 13 Jan 2012, 21:04
by AdamB
I've had this before Harry and it could be various things.
Firstly, are you using a continuous ink system (CIS) or individual cartridges?
If using the CIS I often found the best way was to click 'change cartridges', getting the head in the position to change. Take out the cartridges, then replace them back where they came from, and wait for the ink to refill (you may have to click on the re-set button depending on the CIS system you have).
It's worth a shot before doing anything else ............
by Paul
what printer this is? and what paper is set in printer driver and what quaity please?
Posted: 14 Jan 2012, 14:47
by colglyn
epson 1400 printer, funky leopard paper, i tried removing the cartridges and replacing them, lines still appeared, nozzle check was still 100% perfect, did head cleans to see if that would shifts the lines, did more head realignement, so i gave up and i took the printer back to the shop i brought it from last weekend and they gave me a new one fingers crossed this will be ok (5 printer in 1 year)
Posted: 14 Jan 2012, 15:37
by pisquee
Did you buy the whole set-up from a shop, or just the printer. If just the printer, and you've been running sub inks through a CISS into it, then they're a good shop for taking it back.
Posted: 14 Jan 2012, 17:00
by colglyn
printer brought from a mayor high street store, they don't know i use ciss system
Posted: 14 Jan 2012, 19:01
by Ian M
pisquee;36501 wrote:Did you buy the whole set-up from a shop, or just the printer. If just the printer, and you've been running sub inks through a CISS into it, then they're a good shop for taking it back.
You just replace the sublimation cartridges with original ones & then they don't know. :wink:
Posted: 14 Jan 2012, 23:01
by JSR
Ian M;36520 wrote:You just replace the sublimation cartridges with original ones & then they don't know. :wink:
Epson will know, but if the retailer has already swapped the printer then it's too late to do anything about it.
Posted: 15 Jan 2012, 01:12
by pisquee
My brother-in-law used to do Epson Express Centre work (not sure if he still does) has a hatred of CISS and sub inks, from one customer who brought one into the shop and proceeded to spill it everywhere! He doesn't like our business at all! LOL
