Page 1 of 2
Re: Printing on mug base?
Posted: 09 Jan 2012, 17:52
by Martinx
I'm interested in printing on the bottom of a mug but have a few questions.
1. Does the sub coating process cover the whole mug, including the base?
2. What's the best way to get a good contact between print and bottom of mug?
3. I assume I would have to use an halogen type oven process?
I couldn't find a post on this so your help is appreciated.
Cheers
Martin
Posted: 09 Jan 2012, 17:54
by smitch6
this has been discussed on here somewhere :)
i think the outcome was water decal or slide decal or whatever it was called lol
i don't think there's a wrap available that does the base :(
Posted: 09 Jan 2012, 18:26
by pisquee
What was also discussed was how good a sublimation coating would actually be available on the base of the mug to be able to sublimate into.
Posted: 09 Jan 2012, 19:18
by Martinx
Thanks guys! I will have to look into the water decals
but I assume this will have an impact in the dishwasher.
I was hoping there was a way of sublimating the
base.
All the best
Martin
Posted: 09 Jan 2012, 19:43
by mrs maggot
people must do them as with the "twat" ones that are around, they are perfectly smooth rather than feeling a decal,
Posted: 09 Jan 2012, 19:47
by Martinx
mmmm that's what I thought.
Posted: 09 Jan 2012, 22:17
by AdamB
I had a thought about this the other day but haven't put it into practice .............
You can buy those ceramic pens that you can write onto ceramics (obviously) - why not create a template in vinyl, stick this onto the bottom of the mug and them colour it in like a stencil?
It might work, but like I said - not put into practice yet .........
Posted: 10 Jan 2012, 00:48
by Paul
Warm. Very warma adam ;-)
On old forum this was one of the most visited treads. I come up with idea that my old.mate eggplant used. Ruber stamp :-) try with water proof ink or i used cheap black sublimation ink ;-) worked great but if ther is nothing heavieish on the print in the oven then lettees are quite blured. But still ok and readable. I created round template with www address and name. Was very profesional and permament :-) i used 11oz.that time andd all of them where coated on the bottom.
Posted: 10 Jan 2012, 07:33
by smitch6
it must be possible somewhere somehow because the orca mugs have a stamp????????????
Posted: 10 Jan 2012, 08:56
by Andrew
Orca and "Twat" are probably Pad printed on. Digital transfer decal would do the job if you had a hot enough oven.
