Re: Things that go bang in the night! (faulty mug blanket)
Posted: 25 Oct 2011, 09:14
Hi all,
just a question really for those electricians around.
My mug press blanket is starting to get worn and frayed on the edges. Yesterday I turned it on (as normal) and when it hit the idle temp the trip switch went off in the shop. I thought the fuse had gone in the cable so I changed it and carried on (did about 10 mugs).
Last night - same thing!
The question is - do I have a faulty press or is the blanket that is frayed causing a short or something? (images below)
[ATTACH=CONFIG]619[/ATTACH] [ATTACH=CONFIG]620[/ATTACH] [ATTACH=CONFIG]621[/ATTACH]
Also, can I confirm something.
The press is a DF1 press bought from BMS and the replacment blankets are £42 - but I looked at the coralgraph website and replacement blankets are only £24.99 (the connections on each look the same from the images shown on the websites)
Links: BMS - http://www.printerowners.co.uk/hardware ... -wraps.htm
Coralgraph - http://www.coralgraph.com/heat-press-ac ... ug-presses
WILL BOTH WORK IN MY PRESS? Obviously, if they are the same then I'm all for saving a few quid!
Many thanks in advance
