Re: VINYL CUTTER / CUTTING PLOTTER 710mm (Mint Condition)
Posted: 28 Sep 2011, 16:22
by AdamB
*CUTTER IS NOW SOLD
Hi all,
I have a VINYL CUTTER / CUTTING PLOTTER 710mm for sale.
I was going to put it on ebay this weekend but I thought I would give members on here first refusal first.
It's hard to believe but the cutter is BRAND NEW (with the exception of testing it when I got it). I bought the cutter at the end of October last year and to be totally honest it has been sat in the box since then as all my designs are cut using my trusty craft robbo. After getting it out of the box and testing it I always wanted to get it out on the worktop, set it up and get it running but I always found time to do something else. Then a few months ago I bought another large cutter so it was never to be.
I paid £270 for the cutter and it comes with a stand (which has never been assembled) and all the bits below.
I am after £180 OVNO as I am sure this is a true bargain form someone wanting one and I can use the cash to invest in blanks for the Xmas Rush
(that's a polite way to say that the missis wants me to get rid of it as I save everything - just in case).
Anyone interested then please PM me - if you want it for £180 then first come first served. Payment via PayPal, and there will be a £20 courier charge as it's quite heavy!
Details/specifications are below (TAKEN FROM THE WEBSITE I PURCHASED FROM) - but I have to stress it's in MINT CONDITION!
TOP PROFESSIONAL VINYL CUTTER/CUTTING PLOTTER 710MM
[ATTACH=CONFIG]563[/ATTACH]
Liyu is the best quality of all the plotters from China. Liyu only use proven technology to avoid any risk and problems for customers. Liyu uses quality metal parts both outside and inside, they are very different to other plotters which have got so many plastic parts inside, this is why liyu plotters can be using for long time without any problems and also it's the reason we can offer 2 years warranty only for liyu.
100-240VAC 50/60Hz Auto-switching (Worldwide)
Compatible with any system: XP, Vista, Win 7 and Mac (Using a Mac adapter)
  • Disc with drivers/videos of how to install
  • Serial & USB Connection
  • (Real 2.0 USB, Can fit any computer and Laptop)
  • 3 Quality Blades
  • Pen Adapter
  • Dual Position Carriage
  • 3 Pinch Roller
  • 2 Superior Ball-bearing Bual Roller
  • Quality Floor Stand
  • (worth more than £50)
  • Aluminum Case
  • Dustproof Cover
Specification:
Model: TC631
Driver: Stepper Motor Control
Media Size: 710MM/27.95"
Cutting Size: 630MM/24.80"
Max Cutting Speed: 800 MM/S
Pinch Roller: 3
Max Pressure: 800 Grams (can cut more than 1mm thick vinyl)
LCD: With
Buffer Capacity: 64 MB
Resolution: 0.025 MM/Step
Repeatability: 0.1 MM/0.0039 IN
Interface: USB2.0/Serial
Features:
  • USB2.0 Interface,Support Hot-Swappable,With Serial Port to support more long-distance data transaction
  • 64MB Super-Memory,Long time Offline Cutting,The data Storage can be achieved even Blackout
  • New High-Speed PIC Remote Control System,Higher Speed while Lower Noise
  • Digital Force & Speed Adjustable,Direct& Steady
  • Humane Design,Allows to adjust cutting force and speed while working
  • High-Precision"Steel Bardbed"Axis,Higher Accuracy
  • Auto Memory of Blade Force & Speed.Ajustable at any time,easy to use
  • Emergency Stop & Stop to return at any time to monitor the cutting quality
  • Unique red cutting slot make it easier to operate
*CUTTER IS NOW SOLD
Posted: 28 Sep 2011, 18:22
by Paul
good price :wink:
should get the buer very quick!
Posted: 03 Oct 2011, 14:34
by AdamB
Anyone interested?
No problem if not as it'll go on ebay this weekend (was a little busy last weekend so never put it on).
PM if interested :-)
Posted: 03 Oct 2011, 15:53
by Paul
Shame i don have much spare cqsh at this moment :-(
Posted: 03 Oct 2011, 17:38
by AdamB
Paul;31477 wrote:Shame i don have much spare cqsh at this moment :-(
no problem Paul - someone will get a bargain when it goes .............. pitty I don't have the room (or an understanding wife) to keep it as a spare :-(
Posted: 02 Nov 2011, 15:20
by AdamB
Ebay sale didn't go through - don't you just hate tiome wasters!
This is still for sale and I will accept £150 plus courier charge ................ if no one is interested I'll try ebay again.
Posted: 02 Nov 2011, 16:03
by JackB
Don't know if you would be interested, but I thought it is worth a try:
http://www.swapz.co.uk/swapz/1844506/re ... ing_lathe/
Jack.
Posted: 02 Nov 2011, 19:33
by AdamB
*cutter is now sold
