Page 1 of 3
Re: Newbie - Please recommend a good mug press that does full wrap prints
Posted: 03 Jan 2010, 22:50
by apples69
I've new to the world of the mug press, so please excuse me for asking basic questions
I want to start printing onto mugs, but I dont have any idea on what mug press to get, i've seen a few mug presses on ebay, but i dont know what i'm supposed to be looking for when buying a mug press
I want to
print full wrap prints onto 11oz mugs that look professionally produced
would you recommend getting a mug press that takes the mug in the upright postion or one that takes the mug on its side?
Posted: 03 Jan 2010, 23:32
I now use the DF10 from BMS, it's a great press. Not sure if any in stock at the moment.
They've recently introduced the
DF1 mug press which is excellent value and is a horizontal press.
Either press will do full wrap. I do 10oz mugs in my DF10 and to be honest I get on far better with it than my previous George Knight DK3 which cost way....way more!
Martin @ BMS is on the forums here so you can PM him if you need more info.
There are plenty on eBay as always but one thing you learn very quickly is the need for help and advice when starting out.
Posted: 04 Jan 2010, 00:12
by Karen.
I am slight biased here after having an ebay mug press catch fire on me.
I have had presses from BMS and would also recommend them.
Posted: 04 Jan 2010, 07:36
by apples69
who are BMS and what does the DF1 press look like?
is it easy to use?
Posted: 04 Jan 2010, 08:31
by mrs maggot
here is the website for Martins Company
BMS
never be afraid to have a good read through the forum in the member to member offers here is the link for the BMS mug press that they are refering to
link to member to member
Posted: 04 Jan 2010, 11:30
My post above contains a link to to the DF1, just click on the bold text.
Posted: 05 Jan 2010, 23:10
by apples69
jnmann wrote:My post above contains a link to to the DF1, just click on the bold text.
i've had a look at the BMS site and the DF1 mug press, they dont have a price on the page
http://www.printerowners.co.uk/heat-presses/528/df1-mug-press.htm
also the mug goes into the press side ways, instead of the normal more natural upright position, is there a reason for this on the DF1 press?
what do you think of these presses on ebay that i have seen, are these as good as the DF1 press?
http://cgi.ebay.co.uk/Sublimation-Ink-Mug-Cup-Heat-Press-CE-Approved_W0QQitemZ270502288171QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item3efb315b2b
http://cgi.ebay.co.uk/New-Type-Mug-Stand-Press-Heat-Press-Transfer-Machine-CE_W0QQitemZ220502800412QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item3356fdb81c
Posted: 05 Jan 2010, 23:16
Use the drop down menu at the bottom to select the press. I've just looked and it's there.
Some folk prefer this orientation, I use the DF10 which is upright and works very well for me.
Both eBay presses look cheap. not to say they won't do the job but if you're going cheap you should be able to get for less than that.
Never underestimate the value of support either. If the press goes wrong or you can't get it working properly, how quickly will the company respond? What is the warranty? Can they supply replacement heat blankets quickly at a fair price?
Posted: 05 Jan 2010, 23:33
by apples69
justin, if i bought from BMS will they help me out if i have problems with the mug press and does it come with warranty?
how long have you had you had your BMS press
what do you think this BMS mug press
http://www.printerowners.co.uk/heat-presses/430/df180-mug-press.htm
and how come its more expensive than the BMS DF1 press?
Posted: 05 Jan 2010, 23:36
The details state that it has a superor heat blanket. I've had mine a good few months now. The heat blanket packed up within the first 3 months but BMS had a replacement FOC with me a couple of days later. I can't fault the service I've had so far.
Check the warranty, usually you get something like 3 months on a heat blanket and a year on the actual press.
Give Martin (BMS) a shout. Use the PM on here if you like, he's often around.
