metal sublimation clocks
Re: metal sublimation clocks
Hi! I know you can get some metal clocks from new metal supplier (ex sublisupply).
I know that some clock mechanism you can hang on the wall as they got this hanging bit on te back. bu how about desktop clocks? metal is to thin to stand alone on te desk so how do you suport this? I have seen some clocks with plastic plate stands but this look pants :( any other way to rest them on the desk??
Depends how they are supplied, but if they are long enough then you can bend the metal to create a self supporting stand.
Reg
Post by Reg »
You could make wooden base with a slot for the clock to stand in bevel the edges and stain the wood.
bms;26984 wrote:Depends how they are supplied, but if they are long enough then you can bend the metal to create a self supporting stand.
thats great idea thi is :) but would coating not crack??
Reg;26987 wrote:You could make wooden base with a slot for the clock to stand in bevel the edges and stain the wood.
it mean more to do and cost is biger. but idea very nice :D
also I wonder if there are any clocks with hole not on the midle?
more on the side like on my pics? I would like few of them...
Reg
Post by Reg »
Not metal but BMS do an offset clock
whats the offset? :redface:
Reg
Post by Reg »
The clock face is to one side like your picture the are free standing or hang on a wall.
alright. thanks for that. are they made of metal??
Coating won't crack when bent. We thought about metal offset clocks, but they would hang straight on the wall, so we just made the square metal clocks.
