picture frame in coreldraw
Re: picture frame in coreldraw
Hi
I might be missing it but how do you create a picture frame in corel draw x5.
I just want to create picture to fit in to a plain rectangle for mug print
Matthew
do you mean mug template with rectangle cut out area???
Yeah i just want to be able to make photo wrap around mug, but can't stretch it as bits go off the rectangle
Matthew
give me few minutes i see what i can doo...
what size you printing ie. sieze of your full wrap??
Cheers Paul
The wrap is 20cm by 9 cm
When i use pageplus or drawplus i just insert picture frame then select image and it places images in box then i can just move it about to where i want it.
Matthew
Draw to rectangles, one about an inch bigger than the other and the smaller one the size of the wrap. Centralise, turn back one (large) to white and front (smaller one) to clear (top box on the colour chart). Select both and trim then delete front one and change the remaining to no outline or white outline. This will leave you with a frame - just put your image to the back and only the part showing through will print.
Hope this makes sense! :redface:
sorry. can not help. can make cutout window for your template in ps only
soory. no much help...
Paul;24846 wrote:sorry. can not help. can make cutout window for your template in ps onlysoory. no much help...
No problem Paul, Thank you for trying though
Matthew
John G;24847 wrote:Try this
[ATTACH]352[/ATTACH]
Thanks John works a treat
Matthew
