Page 1 of 2
Re: Epson 1400 - Printing to one side
Posted: 12 Jun 2011, 19:08
Might be an obvious answer to this...I hope! but I thought I'd ask on here to try and speed things up a bit.
My 1400 seems to be printing to one side, tried different software and it keeps doing it:frown:
Looks fine on screen, tried fit to page and other things but nothing helps.
Anyone got a quick and easy solution to this please!?!?!
Posted: 12 Jun 2011, 21:42
Changed papers size to A4 and it works fine...uhm
Posted: 12 Jun 2011, 23:20
by purpledragon
you runnin windows 7 by any chance ?
Posted: 12 Jun 2011, 23:34
Win XP, never seen this problem before :-(
Posted: 13 Jun 2011, 00:07
by John G
It was probably set to print letter by default
Posted: 14 Jun 2011, 21:12
No-one and ideas here? Need to get an A3 printed tonight and just can't work this one out. Tried printing from a different PC, new driver etc. but still prints to the side so it must be something to do with the printer itself surely?
Posted: 14 Jun 2011, 21:23
by bms
Is it set to US Letter A3, i.e. 11 inch x 17 inch rather than International A3 of 297mm x 420mm?
Posted: 14 Jun 2011, 21:27
Nope, everything's as it usually is...A3 297x420 etc. I have the settings all saved as default. Installed on the other PC with basic settings just to check.
Posted: 15 Jun 2011, 12:22
by Ian Mc
I'd suspect the driver, personally. How did it fare on the other PC?
Just out of curiosity, have you tried building a custom A3 size in Print Server Properties and seeing what happens when using that size?
Posted: 15 Jun 2011, 20:02
Same probs on other PC, tried changing paper sizes
