I have been asked to do some notice boards A1 size, makes a change from t shirts and mugs. But (theres always a but) Im using Chaucer font and it seem to have jagged edges, infact all the fonts look jagged. Is this because its such a large size, or am I missing something.
Cheers Mick. BTW is there any vinyl suppliers between sheffield and leeds anyone can recommend as I have a delivery up there.
Jagged edges
phoenixalpha
Re: Jagged edges
Proper vector fonts should scale up or down to any size without jagged edges unless you have put the font into photoshop or an image editing software.
- mrs maggot
Re: Jagged edges
what programme are you cutting with ?? you should be cutting direct fonts from there
Re: Jagged edges
Does it look jagged on screen or when cut. In my program the fonts look a little rough but cut clean
Re: Jagged edges
I did my design in photo shop then used a program to convert to vector graphics, that might have been my problem. I use flexisign so I will try doing it direct from there, last night I tried direct from flexi but never cut it out due to it looking jagged before cutting. Looks like I will be experimenting tonight.
Ride it like you stole it shiny side up.
phoenixalpha
Re: Jagged edges
You are all stars just tried it with the font straight into flexi and it looked jagged as before but cut out perfect. Your all life savers, so now im going to vectorize the bitmap image then put the text in direct into flexi.
Thanks again people.
