Re: B1100 No yellow
Posted: 13 May 2011, 09:57
by Mattie
Hi
I installed my new Epson B1100 on Tuesday and used it a few times but i've notice there is not much yellow in the tube from the ciss, other colours are fine.
Should i use syringe in bottom of cartridge to pull ink through?
Re: B1100 No yellow
Posted: 13 May 2011, 21:57
by bms
Is it printing okay and is the yellow pulling through as you print?
Re: B1100 No yellow
Posted: 14 May 2011, 09:02
by Mattie
Hi
It's printing ok now but the yellow is not moving in the tube
Re: B1100 No yellow
Posted: 24 May 2011, 07:10
by busybusybee
I had this the other day, had to use the needle/syringe to pull the ink through the pipes, no problems after that :)
