Page 1 of 3
Re: What's the best way to do this?
Posted: 05 May 2011, 10:03
by danlad
Hi,
I have got 15 t shirts to do with a green and white logo that is attached.
What is the best way to do this? Will it need to be 2 layers the same size, white on the bottom and green on the top?
If there is 2 layers, what will the press time per layer?
Posted: 05 May 2011, 10:22
by mgibbs
I would press a square of green then press the white.
I've always used the recommended press time for each layer.
Mark
Posted: 05 May 2011, 12:25
by Paul
whats the colour of tees mate? If white then only vinyl. If other colour of tees then i would use flock to do that. Grean first then white inside the letters.
Posted: 05 May 2011, 12:35
by danlad
hi Paul, the colour of the t's are pink, I've already got the vinyl though:-(
Would you put a green square down first then lay the letters on that, or would you cut the letters out of the green and put the white letters inside?
Posted: 05 May 2011, 13:05
by Paul
green first mate. Otherwis it would be bagger to line it up
Btw. Whats your vinyl? Flex or flock?
Posted: 05 May 2011, 13:07
by mgibbs
Having thought about it again, if you put a rectangle of white down first and then press the green "stencil cut" layer on top then there'd be no alignment of the letters to do so should be a quicker, easier job.
Mark
Posted: 05 May 2011, 15:42
by Paul
would white squere not be visible??? flock is quite thick.
Posted: 05 May 2011, 15:58
by mgibbs
He's using vinyl so would probably get away with it.
A trial on some scrap fabric would see.
Mark
Posted: 05 May 2011, 16:23
by John G
I'd put the green down first then line up the white ontop. Putting white block down first will give you visible overlaps. Wouldn't be too hard to put reg/guide marks on the white.
Posted: 05 May 2011, 17:11
by Paul
same as john here
