Re: 8 in 1 heat press
Posted: 03 May 2011, 08:56
by hakuna
hi, ive just bought the 8 in 1 heat press from corelgraph and was wanting to find out how long you have to heat it up before pressing anything, also would i have to use any teflon sheets with it as well.
thanks
malcolm
Posted: 03 May 2011, 09:04
by Paul
I got 5in1 i bought years a goooo and it takes about 10-15 minutes to heat up main element (flat bed). there is a temp display so dont waorry
you will know exactly when is heat up to your temp. also I would recomend to use teflon sheet or grease proff paper to keep your press clean.
Posted: 03 May 2011, 09:21
by hakuna
thanks for the reply paul, ive not used it yet but will have a go tonight thanks again.
malcolm
Posted: 10 May 2011, 15:30
by hakuna
hi paul i just did my first placemat that i bought from bms and it came out perfect except that the middle of the placemat was bowed any ideas why this would happen i pressed it at the settings on bms webpage 185c and 50 -60secs have you any ideas how to avoid this.
thanks
malcolm
Posted: 10 May 2011, 16:58
by Paul
they do bend a bit. you need to put something heavy on them stright after you press them. thats what other recomend any way
Posted: 10 May 2011, 17:03
by hakuna
thanks for that reply paul cheers
Posted: 10 May 2011, 19:08
by bms
hakuna;22363 wrote:hi paul i just did my first placemat that i bought from bms and it came out perfect except that the middle of the placemat was bowed any ideas why this would happen i pressed it at the settings on bms webpage 185c and 50 -60secs have you any ideas how to avoid this.
thanks
malcolm
FAQ on this matter at...
http://www.printerowners.co.uk/faq/12/1/sublimation-advanced.htm
