Magic water decal paper - has anyone used these?
Discuss other print methods.
barryslip
Re: Magic water decal paper - has anyone used these?
Post by barryslip »
Hi all
Not sure if I have started this in the right forum - I'm sure Paul will move it if not LOL!
I've been reading about these "magic water decal papers" online at www.craftycomputerpaper.co.uk today.
Basically, print using a colour laser printer, soak, place onto blank ceramic and bake to make it dishwasher proof. Sounds very simple and, as far as I can tell, has a load of uses (logo on the bottom of a mug, decorating large items - biscuit barrels, coffee jars etc).
So, not having used any type of water decal before, I was wondering if anyone has used this particular type?
There are some cheap laser printers around the £130 mark, so was contemplating giving it a go.
Cheers
Barry
Everything you sayid correct, but where is the dishwasher guarantee of this once it has been stuck to the ceramic? In principle this is a glue activated clear material that slides and dries onto the ceramic, candle, tin etc but as the glue is water activated then the dishwasher may 'deactivate' it. We've been selling this for years but have never claimed the permanency of dishwasher proof. Interested to hear if such tests have been done.
barryslip
Post by barryslip »
There is a video on here http://www.craftycomputerpaper.co.uk/pr ... er_256.htm - within 30seconds the phrase "...to make them dishwasher proof..." is mentioned. I'll contact them to ask the question, and post back.
barryslip
Post by barryslip »
Martin - correct me if I'm wrong, but your site also states "The transfers when cured at 180 degrees C become very durable and dishwasher safe at low temperature settings."
I'm confused!!!!!
mrs maggot
Post by mrs maggot »
is it worth checking out this thread ? http://www.dyesubforum.co.uk/vbforum/sh ... -etc/page3
At low temperature settings - so you would be washing at cool temperatures, not what I would want to wash my normal dishes at. Given the amount of steam and the temperature of the dishes when they have been washed in automatic mode then I can't imagine the decal material withstanding that degree of heat and steam (if there are repeated tests conducted to say otherwise then I stand corrected). Cool/ rinse settings would be okay, but this is like washing/ spraying with luke warm/ cold water.
i am even more confused now :) i always thought "diswasher safe" is all about chemicals used in dishwasher not temperature :) people learn every day...
Paul;17961 wrote:i am even more confused now :) i always thought "diswasher safe" is all about chemicals used in dishwasher not temperature :) people learn every day...
Certainly is for things like RN coated mugs or other sublimation coatings, but when you just stick something on the outside of the mug like a decal then hot and steam will have quite an impact.
barryslip
Post by barryslip »
Thanks Martin. I guess I'd need to advise customers to "hand wash only". Then there should be no issues with steam/hot temps etc?
barryslip;17970 wrote:Thanks Martin. I guess I'd need to advise customers to "hand wash only". Then there should be no issues with steam/hot temps etc?
I would unless there are tests done to confirm otherwise - you could always do one and put it in your dishwasher. Let us know how you get on in say 3 to 6 months!
Users browsing this forum: Baidu [Spider] and 0 guests
