Time V Temperauture
Posted: 28 Feb 2026, 09:26
by JMugs
Let's consider just mugs to keep it simple.
Higher the temp the lower the time.
Too much temp burns
But beyond that
Say 160 degrees V 200 degrees advantages or disadvantages?
As I see it lower temp allows more wiggle room with time.
Does it allow a deeper penetration into the coating?
More even print as the mug has more time to reach an even temp everywhere (especially close to the base).
High temp allows more mugs printing.
Is that it? Am I wrong in the above thoughts? Is there a "best" way that out strips everything else?
Martin
Re: Time V Temperauture
Posted: 28 Feb 2026, 13:56
by GoldRapt
I would love to answer this Martin but I havnt played with mugs for over 10 years.
Maybe Ill play again but I got rid of my mug press.
I dont even knoiw what powple are using these days... air fryers/ovens/special ovens/mug presses etc.
I do understand time. temp and dwell so presumably your dwell is the same but the only question I have is
If you have a set time at the higher temp, how have you calculated the correct time at the lower temperature, is there a guage that you use or is it rue of thumb/experimentaion plese?
Tony
Posted: 28 Feb 2026, 20:27
by JMugs
Hi Tony
It's been trial and error. I get curious and start exploring variations.
Many years ago I read an article about sublimation on outdoor signs. The recommendation was low and slow for durability, but there was no explanation or proof of why.
If this (low and slow) does create better durability it's useful for mugs.
I have found that hot and fast means over cooking happens quick, but that is an obvious event.
I have just switched from presses to an oven, hence playing with time / temp again. :D
Posted: 01 Mar 2026, 10:27
by GoldRapt
My presses were the halogen twin deck from Magic Touch with the big rubbery/canvas wraps.
I have plans to do mugs but not in quantities that would require an oven.....I don't think.
Posted: 01 Mar 2026, 20:37
by JMugs
Ahhh I remember those. I have one of the big metal clamps floating around here. Unused so one day it may have novelty value. :D
