Large (13/14oz) Balmorals
whitprints
Re: Large (13/14oz) Balmorals
Anyone know of any UK stock of the Large Balmorals, no issues on the standard 9oz Balmorals, but struggling to find anyone with the Large version available
- UK Printed Mugs
We use to buy from MDP the larger ones but had to stop about two years ago as quality is shocking - 8 out of 10 would crack in the press. Since then we have not found any worth buying. Although please bear in mind we uses presses and not an oven.
whitprints
Thanks Olly,UK Printed Mugs;154774 wrote:We use to buy from MDP the larger ones but had to stop about two years ago as quality is shocking - 8 out of 10 would crack in the press. Since then we have not found any worth buying. Although please bear in mind we uses presses and not an oven.
I went over on Sunday and grabbed a few hundred of them as an alternative, but sadly we have some regulars that like the Balmoral shape although they are a pain to do due to the large taper on sides so templates have to be handcut , done a few tests of the 15oz you mentioned and no issues so far
Will have to get better at stock control!!!
