Re: Mug blanket for Genie 3 Mug press
Posted: 08 Nov 2023, 12:10
by Jessie
I need to replace my 10/11oz mug press blanket. My press is from Listawood and it's the Genie 3 model and has the 4 pin prongs (pic attached). They're not in stock at Listawood and will take a few weeks to get in. * Does anyone know where else I could get one from that's in stock?
Thanks in advance :)
[ATTACH=CONFIG]7246[/ATTACH]
Posted: 08 Nov 2023, 12:29
by knightweb
I had the same problem a couple of months ago
Eventually, I found a replacement on ebay (Signzworld), out of stock on thier web site but had them on ebay
I'm not sure if mine is a Genie 3, but my model number mached & is the same plug as your photo. It works fine
https://www.ebay.co.uk/itm/302192639119 ... 2189438678
Posted: 08 Nov 2023, 17:35
by Jessie
Thank you. I will check it out :)
Posted: 08 Nov 2023, 19:52
by UK Printed Mugs
It's also known as Arc press and you can buy elements from magic touch
https://www.themagictouch.co.uk/product ... t-10-11oz/
Posted: 09 Nov 2023, 11:43
by Jessie
Thank you - I needed some mugs from there so I can order the mug blanket too.
Posted: 15 Nov 2023, 23:04
by Baldy
