Re: Sale of All our Sublimation manufacturing, Digital printing & Business equipment. UK
Posted: 22 Jun 2023, 21:12
by moocowstudios
  • We are selling all our Sublimation manufacturing, Digital printing and Business equipment, due to closing our business.
  • Open to sell items individually.
  • Buyer collects or arranges collection.
  • Where machines require a competent person or engineer to prepare for transportation, this cost is to be discussed with us first.
Due to business closing down, the office email is only checked once or twice a day
Any immediate questions can be made to Martin on 07871 230100 who will either answer questions or take a message.
MIMAKI UJF-6042 Mk 2 Flat bed UV printer £15,000
UJF-6042Mkll is an advanced flatbed UV-curable inkjet printer, capable of printing to multiple substrates, curing the ink during the same cycle. Rigid & flexible materials can be printed on depending the type of ink set up. Specialist inks enable images to stand out on dark materials, whilst Primer & clear allow use of different materials and provide a protective layer if required.
High-performance inks expand the range of applications, choice of LH-100 OR LUS-120 ink.
Mimaki's unique print-quality management enhances colour representation.
Maintenance functions ensure worry-free print operation.
Works with sophisticated RIP "RasterLink 6" software.
Print on almost anything thanks to 153 mm head height.
Printable area of 60cm x 42cm.
This machine is currently set up with LH100 inks for printing on rigid objects with Cyan/Magenta/Yellow/Black/Primer/Clear and 2 Whites
UJF-6042Mkll as previous except this machine is currently set up with two extra colours to create really accurate vibrant designs.
This machine is currently set up with LH100 inks for printing on rigid objects with the following inks Cyan/Magenta/Yellow/Black/Light Cyan/Light Magenta/White/White.
MIMAKI TX300P 1800 Textile wide format printer and MURATEX Drum Heat Press See below for spec. £15,000 the pair
The Tx300P-1800 has the capability to print directly onto almost any type of natural or man-made fabric such as cotton and polyester. There are several ink types available for the Tx300P-1800 including sublimation, disperse, reactive, acid dye & textile pigments for a range of applications / textile types. The high print quality makes it perfect for fashion, sportswear, soft signage and upholstery.
It can also be used as a Hybrid printer, with the ability to load textile pigment ink for natural & cotton materials as well as sublimation dye inks for polyester.
This machine is currently set up with TP400 Textile Pigment inks in the following configuration: Cyan/Cyan/Magenta/Magenta/Yellow/Yellow/Black/Black.
Can be loaded either as sheet or rolled material upto 100metres long.
Model: DFPM1800
Manufacturer: Muratex
Serial/Service: 1715
A wide format heat press perfect for the bonding of inks to textiles. This machine has adjustable temperature and speed settings to ensure that different inks and substrates bond as per the manufacturers instructions. A roll to roll capacity in excess of 100 metres this machine is great for higher capacity production, large format designs or multiple designs printed on one roll.
3 Phase power supply. Programmable heat and speed settings
Multiple safety features and emergency stop buttons and wire. Cover has vent for
extractor fan connection.
Can press material up to 1800cm wide.
Sureprint Tunnel Oven £13,000
Model: Sureprint Electric Custom Oven
Manufacturer: Sureprint
Serial: 10/2021/55
Dye sublimation oven with continuous mesh conveyor-belt, designed for heat transfer of sublimated designs onto mugs or other products.
Fitted with a large cooling fan, that reduces the temperature of the sublimated items quickly after exiting the oven, produces products with very vibrant colours.
Measuring only 1.1m wide, has a 0.6m loading area, 2.2m length oven, 1.5m cooling area, overall length being 4.3m
Overall height with cooling fan is 1.78m
3-phase electric with 4m power connection cable. Fitted with a precise digital temperature controller and speed controller for accurate simple precise control.
Multiple heating elements for full even heat coverage.
Throughput upto 1000 mugs a day.
Safety switches & Emergency stop.
XEROX J75 Digital Printing Press £3,000
This is the version that contains the High Capacity SRA3+ feeder, Booklet maker and DeCurler.
A centre of a complete digital printing solution with Automated Color Quality Suite(ACQS) colour management tools to improve colour stability, accuracy and repeatability. Scanner, Copier, Printer, Booklet maker, with load while run cartridges, high capacity feed tray and amply paper tray storage for different types and sizes.
Comes with EX J75 Xerox command unit loaded with Fiery control & support software for printing and management of job flow.
Speed B/W: 75 Pages Per Minute
Speed Colour: 75 Pages Per Minute
Resolution: 2400 x 2400 dpi
Paper Capacity: Six Drawer
Volume: 450,000 Copies Per Month
Toner Impressions B/W: 20,000 Impressions, Color: 22,000 Impressions
XEROX WorkCentre 6655 A4 Colour Multifunction Laser Printer £250
Print, copy, scan and fax faster with print speeds of 35ppm as standard in both colour and mono. In addition, features like 'intelligent printer' allow automatic prioritisation. With a large, comprehensive and easy-to-use colour touch screen. It also comes with a Flat bed and feeder tray scanner.
A4 Multifunction
Automatic Duplex
2400x600 dpi Resolution
35ppm Colour/35ppm Mono
550 Sheet Paper Tray
150 Additional Tray
USB/Network Connections
Xpress ADKINS Omega 750 Heat Press £3,000
Model: OMC750
Manufacturer: Adkins
Serial: 5020.140
Pneumatically operated, single table heat press featuring a large pressing area, with a sliding lower table perfectly suited for medium to high volume production environments.
The pneumatic operation allows you to replicate exact pressure with every press cycle.
The operator controls the pressure via a simple, fully adjustable air pressure gauge and locking air pressure control. Easily adjustable time and temperature set via the controller and the LED display.
Twin button control system ensures the operators hands are clear of the pressing area.
Emergency stop button that shuts off machine operation.
Heat plate will not operate until directly aligned over the lower table.
Pressing Area slightly over 70cm x 100cm
Requires 3 Phase electrical supply
AUSJETECH
MC-35M Auto Creaser £875
MC-35M is an easy to operate semi-automatic desktop card creasing machine producing the same high level matrix creasing as more expensive machines. Can crease litho or digital print.
Creases while preventing digital toner cracking. Up to 2220 sheets per hour can be stream-fed by hand, simply advance the sheet from the feeder tray to the input rollers.
Up to 2220 sheets per hour (A4 single crease).
Crease width 1.0mm.
From 1 - 32 creases.
Programmable memory.
Takes paper between 128-350gsm (creasing)
Up to SRA3 size stock.
Min size 50 x 90mm.
Max size 330 x 900mm.
Manual Creaser £75
EBA 485 EP Guillotine £2,000
Manufacturer: Krug & Priester GmbH & Co
Serial/Service: 485 1243
The EBA 485 EP offers programmable control over the back gauge, auto-clamping and a power driven cutting blade. Programmable to 99 cutting programs & up to 99 steps in each. A memory key can recall repeat cuts while non-standard job sizes can be entered via the key pad to control the back gauge. Manual setting is also possible for the finest adjustments. Cutting position is checked using illuminated cutting line. Ejects paper after cutting.
475mm cutting length
80mm cutting height
35mm narrow cut
Programmable
Digital backgauge
Memory key for repeat cuts
Auto clamp & knife action
Optical cutting line
EPSON 9800 wide format printer £750
Serial/Service: GLS0003780
The Epson Stylus Pro 9890 Printer is a professional 44 inch large format printer that combines accurate colour with high productivity at speeds of up to 40m2/hour. It is designed with the print requirements of the commercial photography and fine art markets in mind, yet also representing a sound choice for the proofing market. This machine is set up for Dye sublimation printing and is currently using Sublinova 8 colour inks for accurate vibrant results.
Works with common photo editing programs for colour accuracy.
USB 1.0/1.1, Ethernet (RJ-45), USB 2.0 connectivity
B0 or 1030cm wide format available.
Roll or sheet media.
EPSON TM-C3500 Label Printer £550
For labels, tickets or tags, the C3500 is designed to print a wide variety of colourful labels in-house.
Print on a wide range of materials, including matte and glossy coated paper and filmic labels.
LCD screen for ink and printer status.
Long-lasting pigment ink.
Nice Label software CD included.
Posted: 27 Nov 2023, 14:15
by Mitch
Hi there, sorry to hear about your business closing down.
What items have you still got for sale?
Posted: 27 Nov 2023, 14:26
by Mitch
Just read the post again .. I will message on the phone number given
