I’m after a mousemat mock-up smart object.
I have tried making one but it just doesn’t look right.
Something like this.
[ATTACH=CONFIG]7193[/ATTACH]
Many thanks.
Does anyone happen to have a mouse mat mock-up
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 4 times
Re: Does anyone happen to have a mouse mat mock-up
- vB_ID:7193
- IMG_2418.jpeg (48.25 KiB) Viewed 3983 times
- vB_ID:7194
- Screenshot 2023-06-06 at 22.42.44.jpg (14.66 KiB) Viewed 3983 times
- UK Printed Mugs
We always use the Photoshop Smart Objects sold for a few pounds from https://www.etsy.com/uk/shop/styledprod ... t-shopname You'll find a few mouse mat mock-ups in her portfolio.
You just need to use a Smart Object with a Layer Mask then you can use any mouse mat product image that you like and alter it yourself. Here is the image you supplied ...
[ATTACH=CONFIG]7195[/ATTACH]
The Smart Object can then be changed to another image ...
[ATTACH=CONFIG]7196[/ATTACH]
The resulting mockup ...
[ATTACH=CONFIG]7197[/ATTACH]
I've uploaded the PSD file here if you want to play around with it - https://webtrek.co.uk/mouse_mat_mock.psd
[Note: When in the Smart Object, turn on the Guides (Ctrl+;)to help centre and position your image, then use Ctrl+S to Save before returning to the main Mockup file].
- vB_ID:7197
- IMG_2418-transformed.jpg (21.2 KiB) Viewed 3983 times
- vB_ID:7196
- 2023-06-07_16-53-05.jpg (95.42 KiB) Viewed 3983 times
- vB_ID:7195
- 2023-06-07_16-41-24.jpg (91.8 KiB) Viewed 3983 times
