Re: Paper / Print Sizes?
Posted: 04 May 2023, 01:03
I'm mainly printing mugs on paper that is 100mm x 240mm.
I thought I would create the design 90mm x 200mm as I felt that would fit the mugs better and avoid fading around the edges near the handles where the heat press cant completely press the paper to the mug.
However when I goto print via PrintManager it Print manager either has an hard time recognising the size and gives me an error stating that the design is bigger than the print surface. I can get round it by changing the layout to use windows settings and not the PrintManager settings or adjusting the settings of PrintManager layout to trim white spaces and center etc.
Once printed I'm finding that the pictures are not central nor are they the right size, mostly smaller than quoted.
I'm stumped as to where I'm suppose to be entering the media size. Windows? The printer itself in control panel? PrintManager print driver in control panel?
Any help will be appreciated.
