Page 1 of 2
Re: L1800 motherboard
Posted: 28 Aug 2022, 13:43
by socialgiraffe
I am on the hunt for an Epson L1800 Motherboard. Desperately hoping that someone on here might have an old donor machine lying around that still has the motherboard.
Fingers crossed
Posted: 28 Aug 2022, 17:44
Do you know if the 1500 shares the same motherboard Simon?
Posted: 28 Aug 2022, 18:11
by socialgiraffe
Pretty sure it does fella.
If you have one let me know and I will ping over an email tomorrow when I am back in the office
Posted: 28 Aug 2022, 18:20
Agh, literally gave 4 blooming printers away recently
I'll double check but think everything gone. I know someone who may have a 1500 but not sure if they got rid, will update.
Posted: 29 Aug 2022, 11:36
by socialgiraffe
Cheers Justin
Posted: 29 Aug 2022, 12:34
by Mrteajunkie
socialgiraffe;151247 wrote:I am on the hunt for an Epson L1800 Motherboard. Desperately hoping that someone on here might have an old donor machine lying around that still has the motherboard.
Fingers crossed
Do you know what the issue is?
Theres a common fault with not powering up and beeping.
This can be an easy fix if your good with a soldering iron.
Posted: 29 Aug 2022, 12:56
by socialgiraffe
That is exactly the problem. WIlling to give it a go, do you have any links on how to do it?
Posted: 29 Aug 2022, 17:06
by Mrteajunkie
You need 4 transistors [FONT=&]2x A2210 and [/FONT][FONT=&]2x C6082.
Very easy to replace you can grab these from your local rs components or cpc Farnell for under a pound each or even sellers charging over the top prices for them on eBay and Etsy.
[/FONT]
https://www.etsy.com/listing/1255172282 ... on-1390-no
Posted: 29 Aug 2022, 17:30
by Mrteajunkie
I also have the service manual for this printer if you want a copy?
Posted: 30 Aug 2022, 09:19
by socialgiraffe
ou need 4 transistors 2x A2210 and 2x C6082.
https://www.etsy.com/listing/1255172...-epson-1390-no
Top man, I am going to order from the link you gave me then it means that I have the correct ones
Would love the service manual. I will DM you my email address
