Epson SC-f2100 DTG - printing from USB
Discuss other print methods.
Re: Epson SC-f2100 DTG - printing from USB
Hi guys,I wonder if anyone got this printer? If so, what's the crack with printing from USB? I used several USB sticks and none of them are showing any images when inserted into the printer. I know those are 100% working USBs too.
Are you using .prn files?
From the net ...
Note: The printer only searched the root folder on the USB memory device for files with a .prn fileextension. If the data is saved in a sub-folder or named with a different file extension, it does not displaywhen the USB memory device is connected to the printer.
I got it sorted now. Found out that you can't just print any file from USB stick. It need to go to Garment Creator and save the file from there. So it contain size and all ink set up settings.
Ravisteam
Post by Ravisteam »
Paul;150835 wrote:I got it sorted now. Found out that you can't just print any file from USB stick. It need to go to Garment Creator and save the file from there. So it contain size and all ink set up settings.
I have a one Paul, do you ?. Do you do DTF using it ?.
not yet. waiting for my powder and film to arrive.
