Re: Ricoh gx e3300 printing to light.
Posted: 09 Feb 2011, 16:33
by danlad
Hi, followed the instructions to a t but when I print, the image comes out much brighter. The image has lost a lot of detail where it Looks over exsposed.
I am using cs5 and it is setup exactly as instructed.
Any help would be great.
Posted: 09 Feb 2011, 20:23
by bms
Are you using PowerDriver software or ICC profile to colour manage.
If PowerDriver then open the jpg image in any package - you don't need to be in CS5 to print with the Ricoh printers.
Posted: 09 Feb 2011, 20:55
by danlad
I'm using the power driver. Will the ICC profile give a better result? Also I am using the Xpres paper.
Posted: 09 Feb 2011, 21:17
by bms
Are you referring to the picture on paper or when it has been transferred to a t-shirt? The image on paper will not look correct as it needs to be pressed into the substrate.
Posted: 09 Feb 2011, 21:30
by danlad
That's what it is then. I'm still waiting for my heat press from lovecuts!!
Wish I'd had the money to buy it from you. I would have had it now.
