Re: Graphtec CE6000-60 Problem
Posted: 05 May 2021, 23:30
by colmac01
Hi everyone, I would be very grateful of any help that can be given. I do my cut lines using Coreldraw I then open the plugin Cuttingmaster 3. This has worked perfectly for me for years. However suddenly the cutter has developed a mind of its own. Upon setting the vinyl in the cutter as roll >front edge position my cutter begins cutting in one spot which is right on the edge of the vinyl. I can't see what it has done as it it literally on the right hand edge of the vinyl. My computer shows the normal screen for cutting master 3 and although the trace cut area is highlighted, when I click to do the trace nothing happens. It will not trace the cut line nor will it cut the design. PLEASE HELP!
Posted: 06 May 2021, 08:14
by Mrteajunkie
colmac01;148114 wrote:Hi everyone, I would be very grateful of any help that can be given. I do my cut lines using Coreldraw I then open the plugin Cuttingmaster 3. This has worked perfectly for me for years. However suddenly the cutter has developed a mind of its own. Upon setting the vinyl in the cutter as roll >front edge position my cutter begins cutting in one spot which is right on the edge of the vinyl. I can't see what it has done as it it literally on the right hand edge of the vinyl. My computer shows the normal screen for cutting master 3 and although the trace cut area is highlighted, when I click to do the trace nothing happens. It will not trace the cut line nor will it cut the design. PLEASE HELP!
im of no help here as I can’t remember what caused it or what cured it.
but I had a similar issue where it cut the whole 30cm x 1m design onto a 3mm strip.
Have you tried the obvious like rebooting the machines?
Posted: 06 May 2021, 10:20
by pw66
You could try cutting through Graphte Studio, instead of cutting master. Export your design from Corel as a 72dpi .eps file and re-open in GS.
Alternatively try reinstalling the drivers and cutting master.
Posted: 06 May 2021, 10:33
by colmac01
Thank you, I think I've tried everything but thanks for your advise.
Posted: 06 May 2021, 10:34
by colmac01
Thank you, I appreciate your advise.
