Silicone mug wraps
gazfocus
Re: Silicone mug wraps
Post by gazfocus »
For those of you that use ovens to print your mugs, what silicone wraps do you use and generally how many mugs would you say you get out of them before they lose too much tension?
garysub
Post by garysub »
We use the silicon wraps (generally a terracotta colour with metal clips at each end that the silicon wraps through) from longforte. Not cheap at about £10 each BUT you can retension them yourself (by pulling the silicon tighter) and you can also buy replacement silicon sheeting from people like this : https://www.silex.co.uk/products/silico ... one-sheet/ which means you can cut and make replacements yourself. The silicon itself then comes down to about £1 a piece!
