Re: HELP please rock slate
Posted: 12 Dec 2020, 22:41
by colebag
[ATTACH=CONFIG]6459[/ATTACH][ATTACH=CONFIG]6460[/ATTACH]Can some tell me what these patches are from in the corners please
Posted: 13 Dec 2020, 09:53
by JMugs
Uneven heat and/or uneven pressure.
Sit down with a coffee and search the forum, there is quite a bit about pressing slates. Nice when they come out right.
Janners
Posted: 13 Dec 2020, 22:57
by colebag
Thanks for your reply I think it was pressure as I have done some before this one and the came out perfect.i checked the quality of the slate and it dropped of on each of the corners where the weird print was so the slate wasn’t flat on the surface I upped my pressure today and was perfect
Posted: 14 Dec 2020, 10:24
by Paul
do you use silicon sheet?
Posted: 14 Dec 2020, 18:17
I press these saltes as follows:
Pre heat for 125 secs
Attach Transfer
Lay sheet over top (paper inbetween)
Press at medium pressure for 600 (yes 600) seconds
I print 2 or 3 at a time and this works perfectly.
Posted: 14 Dec 2020, 23:36
by colebag
Yes I use a silicone sheet on the top
Posted: 14 Dec 2020, 23:40
by colebag
I’m pressing mine at 200 for 460 seconds with silicone sheet I done some today and they come out great so I think it was my pressure as check now when I’m setting my pressure to make sure its making contact all over the slate
Posted: 14 Dec 2020, 23:48
Yes that's often the problem getting a consistant pressure, this is why I use the mat on top.
Posted: 15 Dec 2020, 00:30
by colebag
Ye well hopefully I have cracked it now it doesn’t help if you have a uneven slate as I put a flat metal ruler on it and sloped of on each of the corners
