Anyone recommend spray adhesive?
W3sty3oy
Re: Anyone recommend spray adhesive?
Post by W3sty3oy »
As in the title can anyone recommend a decent fairly priced spray adhesive for sublimation?
Mrteajunkie
Has thanked: 6 times
Been thanked: 4 times
Post by Mrteajunkie »
3m scotchweld 75
Post by GoonerGary »
It doesn't work on hard products though, only textiles.
Angela-L
Post by Angela-L »
As a newbie, could someone tell me what you would need spray adhesive for? Not read anything about this being used in the process.
Mrteajunkie
Angela-L;146231 wrote:As a newbie, could someone tell me what you would need spray adhesive for? Not read anything about this being used in the process.
You don’t actually need it.
if you do a lot of fabrics it’s handy to give it a little light spray and this will hold the paper in place while you press instead of heat tape.
Don’t use it on hard surfaces though.
I give a very light spray to the paper and place it where I want it and the handy part is you can remove it and reposition it.
Angela-L
Post by Angela-L »
Mrteajunkie;146232 wrote:You don’t actually need it.
Cheers for the info. I never would have thought of that, as I would have assumed that it would interfere with the print! Thanks again.
