Hi,
Don't know what I'm after is possible so also after some advice as well as looking for someone (UK based) to produce an A4 sheet of ghost white print
Basically I'm after placing white print onto a black aluminium flat sheet? Is this possible with the white toner sublimation technique ? Or is there another way ?
If so then I'm after finding someone who would be interested, for a fee of course in producing the text ready for me to transfer onto the black ali
Any help appreciated
Mark
Ghost white toner printing request
Re: Ghost white toner printing request
Hi Mark
I can't help as I use OKI White toner system and to be brutally honest I am way too busy anyway.
However have you thought about purchasing white metal panels (somewhere like Subli Metals) and then printing the black? They can custom cut etc etc and not only would it be cheaper (I think), but would also be considerably more durable.
Sublimating metal takes quite a bit of practice so if you go down this route be prepared
Xpres_Adam
Hi Mark,
How big is the piece of material?
Have you tried a single colour vinyl using self adhesive?
You could consider doing this with UV printing to the surface and then lacquering the surface or printing a clear UV ink over the white.
Adam
Adam
Adam Roberts | System Specialist
Tel: 01332 85 50 85 | DDI: 01332 85 53 29
Fax: 01332 85 50 80
Web: www.xpres.co.uk
Email: Adam.Roberts@xpres.co.uk
Fax: 01332 85 50 80
Hi,
thanks for the advice. your suggestions have given me some new ideas
Cheers
mark
Cheers
mark
