Page 1 of 2
Re: Printing from Photoshop
Posted: 10 Oct 2020, 13:57
by GoonerGary
I want to run two printers from the same Photoshop to help speed up the printing of orders. The problem, is that Photoshop crashes as soon as it tries to print...because it is trying to look for a different printer to the one it was using previously. ie it only likes printing to one printer.
Does anyone run two printers, or is it wiser to run a second computer instead?
Posted: 10 Oct 2020, 17:18
by UK Printed Mugs
This is a bug in Photoshop. Been going on for at least a year. Adobe just will not fix it and lots online about it. The workaround we use is to copy and paste the artwork into a new document before printing.
Posted: 10 Oct 2020, 18:01
by GoonerGary
Yeah I read about that bug, but wasn't sure if it was fixed in later versions. I print from A4/ A3 templates etc which have trim guides and I insert the designs into those print ready templates. So making new documents each time is just extra work.
One of my printers decided that it wants another waste ink reset after lying idle for months and me spending an hour cleaning the inside of it yesterday. Nice timing! So I'll just install its backup onto the other computer.
Posted: 10 Oct 2020, 18:47
by webtrekker
UK Printed Mugs;145113 wrote:This is a bug in Photoshop. Been going on for at least a year. Adobe just will not fix it and lots online about it. The workaround we use is to copy and paste the artwork into a new document before printing.
Yeah. I've made a few posts on the Adobe forum about exactly this problem. They just don't want to know.
The way I get around it is to run a cracked copy of CS5 for printing. Much, much better. I'm not bothered about doing that either as I still pay monthly for the latest CC version and Adobe, in their infinite wisdom, won't allow subscribers to download earlier versions now.
Stuff 'em!
Posted: 10 Oct 2020, 20:43
Oh jees, that bug! They still deny it! I had the problem with just one printer. Bit the bullet and upgraded to CC to save hassle, just what they want you to do
Posted: 10 Oct 2020, 23:22
by webtrekker
The know-it-all's on the Adobe forum always replied wit the old 'reset your Photoshop settings' mantra. What a p*ss-take! Every time you reset your settings you then have to re-enter all your old settings again, assuming you kept a note of them, that is.
Posted: 10 Oct 2020, 23:51
by webtrekker
GoonerGary;145112 wrote:I want to run two printers from the same Photoshop to help speed up the printing of orders.
BTW, are you just repeat printing stored designs/images? If so, then why not save them as PDF's along with the relevant ICC profile and then just print the PDF's as and when required, without any Photoshop involvement?
I have printed sublimation prints like this with the correct ICC for my setup and they print fine.
Posted: 11 Oct 2020, 17:23
by pisquee
If printing the same designs, tick the box in windows printer driver to save the file in the print queue, then you can just right click the job and select restart,. and it'll print it again ... we have this - each product type has its own print queue (sending to the same printer) and all the designs we regularly print for that product are saved in the queue, so for core designs, we don't need to open photoshop, just the print queue.
Also, Google for setting up a "print pool" - this is effectively what you want for multiple printers (assuming the printers are the same model) the printers/windows will decide which printer to send to spread the work load.
Posted: 11 Oct 2020, 23:41
by Mrteajunkie
pisquee;145128 wrote:If printing the same designs, tick the box in windows printer driver to save the file in the print queue, then you can just right click the job and select restart,. and it'll print it again ... we have this - each product type has its own print queue (sending to the same printer) and all the designs we regularly print for that product are saved in the queue, so for core designs, we don't need to open photoshop, just the print queue.
My god that’s genius !!!
Thank you I’m going to try that tomorrow.
I have all the designs saved in Ps but can only print one at a time so while sub work is printing I can print my edible ink stuff too now then?
Posted: 12 Oct 2020, 09:35
by pisquee
You should be able to print to both printers at the same time even from Photoshop.
As long as your driver is set to start printing straight away, not when the whole page is spooled.
Unless it is taking so long to spool that it is locking up your machine... in which case, get another SSD just for your print spool file, especailly if you are going to be keeping jobs permanently saved in the print queue, you should definitely have a seperate SSD just for that, and then another seperate SSD for the Windows Page File, and the Photoshop Swap file ... At least 3 SSDs in total - one for the OS, programmes etc, one for the printer, and one for the page/swap files.
You could go further and seperate the programmes and OS if you want. And another for files (although we use a 4 bay NAS for files)
